Использую следующий скрипт для первоначальной настройки моего роутера RB411AR:
/ip address add address=192.168.1.201/24 disabled=no interface=ether1 add address=192.168.0.1/24 disabled=no interface=wlan1 /ip pool add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254 add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254 /ip dhcp-server add address-pool=dhcp_pool1 disabled=no interface=ether1 lease-time=3d name=dhcp1 add address-pool=dhcp_pool2 disabled=no interface=wlan1 lease-time=3d name=dhcp2 /ip dhcp-server config set store-leases-disk=5m /ip dhcp-server network #add address=192.168.1.0/24 dns-server=4.2.2.2 gateway=192.168.1.1 #add address=192.168.0.0/24 dns-server=4.2.2.2 gateway=192.168.0.1 #add address=192.168.1.0/24 dns-server=4.2.2.2 gateway=192.168.1.1 add address=192.168.0.0/24 dns-server=4.2.2.2 gateway=192.168.0.1 /system ntp client set enabled=yes mode=unicast primary-ntp=50.19.122.125 /interface wireless set wlan1 band=2ghz-b/g default-authentication=yes disabled=no mode=ap-bridge #/ip dhcp-client #add interface=ether1 disabled=no /ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade src-address=192.168.0.0/24 to-addresses=0.0.0.0 /ip neighbor discovery set wlan1 discover=yes /ip route add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.1.1 scope=255 target-scope=10 #/interface wireless security-profiles #set [ find default=yes ] mode=static-keys-required static-algo-0=40bit-wep static-key-0=abcdeabcde #/ip dns #set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=4096 servers=192.168.1.1 #/ip dns static add address=208.180.42.68 disabled=no name=ns1 ttl=1d add address=208.180.42.100 disabled=no name=ns2 ttl=1d #add address=208.67.222.222 disabled=no name=ns1 ttl=1d #add address=208.67.220.220 disabled=no name=ns2 ttl=1d /ip address #add address=192.168.1.201/24 disabled=no interface=ether1 #add address=192.168.0.1/24 disabled=no interface=wlan1 /ip pool #add name=dhcp_pool1 ranges=192.168.1.2-192.168.1.254 #add name=dhcp_pool2 ranges=192.168.0.2-192.168.0.254 /ip dhcp-server #add address-pool=dhcp_pool1 disabled=no interface=ether1 lease-time=3d name=dhcp1 #add address-pool=dhcp_pool2 disabled=no interface=wlan1 lease-time=3d name=dhcp2 /ip dhcp-server config set store-leases-disk=5m /ip dhcp-server network #add address=192.168.1.0/24 dns-server=4.2.2.2 gateway=192.168.1.1 #add address=192.168.0.0/24 dns-server=4.2.2.2 gateway=192.168.0.1 #add address=192.168.1.0/24 dns-server=4.2.2.2 gateway=192.168.1.1 #add address=192.168.0.0/24 dns-server=4.2.2.2 gateway=192.168.0.1 /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods=“” group-ciphers= aes-ccm group-key-update=5m interim-update=0s management-protection=allowed management-protection-key=“” mode=dynamic-keys name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode= no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=xxxxxxxxxxxxxx wpa2-pre-shared-key=xxxxxxxxxxxxxxxxxx add authentication-types=wpa-psk,wpa2-psk eap-methods=“” group-ciphers=aes-ccm group-key-update= 5m interim-update=0s management-protection=allowed management-protection-key=“” mode= static-keys-required name=profile1 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=40bit-wep static-algo-1=none static-algo-2=none static-algo-3=none static-key-0=aaaaaaaaaa static-key-1=“” static-key-2=“” static-key-3=“” static-sta-private-algo=none static-sta-private-key=“” static-transmit-key=key-0 supplicant-identity=“” tls-certificate=none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=“” wpa2-pre-shared-key=“” / password old-password=“” new-password=xxxxxxxxxx confirm-new-password=xxxxxxxxxx ######################################
Использовать какую команду, чтобы установить профиль безопасности wlan1 в “profile1”? Сейчас он настроен на “default”.
Спасибо, Дональд Джеймс.
