/ip route print 0
S 0.0.0.0/0 r 192.116.xxx.1 1 link 1 DC 192.116.xxx.0/25 r 0.0.0.0 0 link 2 DC 80.179.xxx.0/24 r 0.0.0.0 0 link
/ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.116.xxx.115/25 192.116.xxx.0 192.116.xxx.127 link 1
80.179.xxx.3/24 80.179.xxx.0 80.179.xxx.255 link
/interface ethernet pr detail
0 R name=“ether1” mtu=1500 mac-address=00:80:C8:F7:7D:7C arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
1 R name=“ether2” mtu=1500 mac-address=00:80:C8:F7:7D:7D arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
2 R name=“Midwest3” mtu=1492 mac-address=00:80:C8:F7:7D:7E arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
3 R name=“OMNI4” mtu=1492 mac-address=00:80:C8:F7:7D:7F arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
4 R name=“PTI7” mtu=1492 mac-address=00:80:C8:F7:7D:24 arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
5 R name=“ENE6” mtu=1492 mac-address=00:80:C8:F7:7D:25 arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
6 R name=“WAR5” mtu=1492 mac-address=00:80:C8:F7:7D:26 arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
7 R name=“EFF8” mtu=1492 mac-address=00:80:C8:F7:7D:27 arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes long-cable=no speed=100Mbps
/interface pppoe-server server print
0 service-name=“Omni” interface=Midwest3 mtu=1492 mru=1492 authentication=mschap2,mschap1,chap,pap keepalive-timeout=disabled one-session-per-host=no default-profile=OMNI
1 service-name=“WAR2” interface=OMNI4 mtu=1492 mru=1492 authentication=mschap2,mschap1,chap,pap keepalive-timeout=disabled one-session-per-host=yes default-profile=WAR
2 service-name=“PTI” interface=PTI7 mtu=1492 mru=1492 authentication=mschap2,chap,pap keepalive-timeout=disabled one-session-per-host=yes default-profile=EFF
3 service-name=“ENE” interface=ENE6 mtu=1492 mru=1492 authentication=mschap2,mschap1,chap,pap keepalive-timeout=disabled one-session-per-host=yes default-profile=ENE
4 service-name=“EFF” interface=EFF8 mtu=1492 mru=1492 authentication=mschap2,mschap1,chap,pap keepalive-timeout=disabled one-session-per-host=yes default-profile=EFF
5 service-name=“WAR” interface=WAR5 mtu=1492 mru=1492 authentication=mschap2,chap,pap keepalive-timeout=disabled one-session-per-host=yes default-profile=WAR
/ppp profile print
0 * name=“WAR2” local-address=192.116.xxx.3 remote-address=WAR2 session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=0.0.0.0
1 name=“MIDWEST” local-address=192.116.xxx.6 remote-address=MIDWEST session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=“”
2 name=“WAR” local-address=192.116.xxx.2 remote-address=WAR session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=“”
3 name=“EFF” local-address=192.116.xxx.7 remote-address=EFF session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=0.0.0.0
4 name=“ENE” local-address=192.116.xxx.5 remote-address=ENE session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=“”
5 name=“PTI” local-address=192.116.xxx.4 remote-address=PTI session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=0.0.0.0
6 name=“OMNI” local-address=192.116.xxx.8 remote-address=OMNI session-timeout=0s idle-timeout=10m use-compression=no use-vj-compression=no use-encryption=no require-encryption=no only-one=yes change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 incoming-filter=“” outgoing-filter=“” dns-server=“” wins-server=0.0.0.0
Настроен 2 публичных IP-адреса и есть 1 подсеть 25 и 1 подсеть 24. Спасибо, надеюсь, это поможет решить мою проблему.
