    ICMP заблокирован (нежелательно).
    ICMP заблокирован (нежелательно)., RouterOS
    Hellbound
    28.07.2005 18:50:00
    Привет, ребята! Я не знаю почему, но пользователи, запущенные от имени, не могут пинговать IP-адреса за пределами роутера. Кажется, ICMP заблокирован, но я не могу найти виновника в моем брандмауэре. Спасибо. / ip firewall
    set input name="input" policy=accept comment=""
    set forward name="forward" policy=accept comment=""
    set output name="output" policy=accept comment=""
    add name="hotspot-temp" policy=none comment="limit unauthorized hotspot clients"
    add name="hotspot" policy=none comment="account authorized hotspot clients"
    / ip firewall rule forward
    add in-interface=onboard action=jump jump-target=hotspot-temp comment="limit access for \
       unauthorized hotspot clients" disabled=no
    add action=jump jump-target=hotspot comment="account traffic for authorized hotspot clients" \
       disabled=no
    / ip firewall rule hotspot
    / ip firewall rule hotspot-temp
    add flow=hs-auth action=return comment="return, if connection is authorized" disabled=no
    add protocol=icmp action=return comment="allow ping requests" disabled=no
    add dst-address=:53 protocol=udp action=return comment="allow dns requests" disabled=no
    add action=reject comment="reject access for unauthorized hotspot clients" disabled=no
    / ip firewall rule input
    add in-interface=onboard dst-address=:80 protocol=tcp action=jump jump-target=hotspot \
       comment="account traffic from hotspot clients to hotspot servlet" disabled=no
    add in-interface=onboard dst-address=:80 protocol=tcp action=accept comment="accept requests \
       for hotspot servlet" disabled=no
    add in-interface=onboard dst-address=:67 protocol=udp action=accept comment="accept requests \
       for local DHCP server" disabled=no
    / ip firewall rule output
    add src-address=:80 out-interface=onboard protocol=tcp action=jump jump-target=hotspot \
       comment="account traffic from hotspot servlet to hotspot clients" disabled=no
    / ip firewall service-port
    set ftp ports=21 disabled=no
    set pptp disabled=no
    set gre disabled=no
    set h323 disabled=yes
    set mms disabled=no
    set irc ports=6667 disabled=no
    set quake3 disabled=no
    set tftp ports=69 disabled=no
    / ip firewall mangle
    / ip firewall src-nat
    add src-address=192.168.1.0/32 dst-address=:!80 out-interface=ether2 protocol=tcp flow=hs-auth \
       action=masquerade comment="" disabled=no
    / ip firewall dst-nat
    add dst-address=:53 protocol=udp action=redirect comment="intercept all DNS requests" \
       disabled=no
    add in-interface=onboard protocol=tcp flow=!hs-auth action=redirect to-dst-port=80 \
       comment="redirect unauthorized hotspot clients to hotspot service" disabled=no
    add in-interface=onboard dst-address=:80 protocol=tcp action=redirect to-dst-port=3128 \
       comment="transparent HTTP proxy for hotspot clients" disabled=no
    add dst-address=192.168.0.1/32:4600-4700 flow=hs-auth action=nat to-dst-address=192.168.1.101 \
       comment="" disabled=yes
    / ip firewall connection tracking
    set enabled=yes tcp-syn-sent-timeout=2m tcp-syn-received-timeout=1m tcp-established-timeout=5d \
       tcp-fin-wait-timeout=2m tcp-close-wait-timeout=1m tcp-last-ack-timeout=30s \
       tcp-time-wait-timeout=2m tcp-close-timeout=10s udp-timeout=30s udp-stream-timeout=3m \
       icmp-timeout=30s generic-timeout=10m
