Привет! У меня такая конфигурация моста: linux_router-------MT_WDS-ap------MT_WDS-station------много ПК на Celerons 2.3MHz, материнские платы с Intel (чипсет, Ethernet и т.д.), карты Atheros. MT версия 2.9.17 с обеих сторон. На стороне AP:
/interface bridge;
:foreach i in [find] do={remove $i}
add name=wds-bridge
/interface bridge port;
add interface=ether1 bridge=wds-bridge
add interface=wlan1 bridge=wds-bridge
/interface wireless
set wlan1 ack-timeout=dynamic
set wlan1 antenna-mode=ant-a
set wlan1 antenna-gain=0
set wlan1 band=5ghz-turbo
set wlan1 basic-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps,6Mbps,9Mbps
set wlan1 basic-rates-b=11Mbps,1Mbps,2Mbps,5.5Mbps
set wlan1 disabled=no
set wlan1 country=no_country_set
set wlan1 default-ap-tx-limit=0
set wlan1 default-authentication=yes
set wlan1 default-forwarding=no
set wlan1 dfs-mode=none
set wlan1 disable-running-check=no
set wlan1 frequency=5920
set wlan1 frequency-mode=superchannel
set wlan1 hide-ssid=no
set wlan1 max-station-count=10
set wlan1 mode=bridge
set wlan1 preamble-mode=short
set wlan1 rate-set=configured
set wlan1 scan-list=5920,5960,6000,6040
set wlan1 ssid=NR_21
set wlan1 supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps,6Mbps,9Mbps
set wlan1 supported-rates-b=11Mbps,1Mbps,2Mbps,5.5Mbps
set wlan1 tx-power=15
set wlan1 tx-power-mode=all-rates-fixed
set wlan1 wds-default-bridge=wds-bridge
set wlan1 wds-mode=dynamic
/interface wireless nstreme
set wlan1 enable-nstreme=yes enable-polling=yes framer-policy=best-fit framer-limit=3200 на стороне станции-WDS: /interface bridge; :foreach i in [find] do={remove $i}
add name=wds-bridge
/interface wireless
set wlan1 mode=station-wds
set wlan1 tx-power=20
set wlan1 wds-default-bridge=none
set wlan1 wds-mode=disabled
/interface wireless connect-list;
add mac-address=00:0E:8E:03:43:EA interface=wlan1 ssid=NR_21
set wlan1 enable-nstreme=yes enable-polling=yes framer-policy=best-fit framer-limit=3200 Мост работает нормально в начале. Примерно через минуту прекращает работу. С другой стороны много ПК. Если попробовать с одним ПК (ноутбуком), все в порядке. Связь хорошая. Если включить большую ЛС, мост перестает работать. После выключения большой ЛС связь начинает работать. Та же ЛС работает без проблем на Роутербоардах с более ранней версией MT. Мне нужно поменять на ПК, поток трафика растет день за днем, а производительности RB слишком мало. Проведены тесты без эффекта: -изменение каналов -отключение turbo-режима -замена карт Atheros -отключение режима nstreme. Интересное наблюдение: Во время сбоя я вижу новые записи ARP в: /interface bridge host print на стороне AP, а Linux-роутер получает много широковещательных ARP-пакетов на Ethernet-интерфейсе. Отправляются повторы. Какие есть предложения? Какие есть идеи? Как протестировать размеры ARP-таблиц в мостах? Есть ли какой-то предел в новых версиях MT? Проблемы со STP, которая отключена? Есть ли аналог команды tcpdump в MT, который может помочь определить точку разрыва соединения? Спасибо большое, femur.
/interface bridge;
add name=wds-bridge
/interface wireless
add name=wds-bridge
/interface wireless
