Привет, ребята. У меня проблема с ограничениями PCQ / деревом очередей.
add name="all-out" parent=global-out flow="" limit-at=0 queue=wireless-default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
add name="128kd-16ku" parent=all-out flow=128kd-16ku limit-at=0 queue=128kd-16ku priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
add name="256kd-32ku" parent=all-out flow=256kd-32ku limit-at=0 queue=256kd-32ku priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
add name="all-in" parent=global-in flow="" limit-at=0 queue=wireless-default priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
add name="16ku-128kd" parent=all-in flow=16ku-128kd limit-at=0 queue=16ku-128kd priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
add name="32ku-256kd" parent=all-in flow=32ku-256kd limit-at=0 queue=32ku-256kd priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0 disabled=no
/ queue type set default name="default" kind=pfifo bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=0 pcq-limit=50 pcq-classifier=""
set ethernet-default name="ethernet-default" kind=pfifo bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=0 pcq-limit=50 pcq-classifier=""
set wireless-default name="wireless-default" kind=sfq bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=0 pcq-limit=50 pcq-classifier=""
set synchronous-default name="synchronous-default" kind=red bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=0 pcq-limit=50 pcq-classifier="
add name="128kd-16ku" kind=pcq bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=132000 pcq-limit=50 pcq-classifier=dst-address
add name="256kd-32ku" kind=pcq bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=264000 pcq-limit=50 pcq-classifier=dst-address
add name="32ku-256kd" kind=pcq bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=32768 pcq-limit=50 pcq-classifier=src-address
add name="16ku-128kd" kind=pcq bfifo-limit=15000 pfifo-limit=50 red-limit=60 red-min-threshold=10 red-max-threshold=50 red-burst=20 sfq-perturb=5 sfq-allot=1514 pcq-rate=17000 pcq-limit=50 pcq-classifier=src-address
/ ip firewall mangle add in-interface=ip-address protocol=tcp tcp-options=syn-only action=passthrough tcp-mss=1360 comment="" disabled=no
add src-address=10.20.130.80/32 in-interface=ip-address action=passthrough mark-flow=16ku-128kd mark-connection=16ku-128kd comment="" disabled=no
add src-address=10.20.130.91/32 in-interface=ip-address action=passthrough mark-flow=12ku-64kd mark-connection=12ku-64kd comment="" disabled=no
add src-address=10.20.130.92/32 in-interface=ip-address action=passthrough mark-flow=16ku-128kd mark-connection=16ku-128kd comment="" disabled=no
add src-address=10.20.130.93/32 in-interface=ip-address action=passthrough mark-flow=32ku-256kd mark-connection=32ku-256kd comment="" disabled=no
add in-interface=!ip-address connection=16ku-128kd action=accept mark-flow=128kd-16ku comment="" disabled=no
add in-interface=!ip-address connection=32ku-256kd action=accept mark-flow=256kd-32ku comment="" disabled=no
well i see in the torch that some costumers are using more than the bandwidth i have specified for them when i torch the specified costumes i mostly see that the excess bandth is through udp ports is there anything wrong in my configuration??? please help me
Я вижу в торе, что некоторые клиенты используют больше полосы пропускания, чем я для них указал. Когда я подсвечиваю указанных клиентов, я в основном вижу, что избыточная полоса пропускания идет через UDP-порты. Не может быть ничего не так с моей конфигурацией??? Пожалуйста, помогите мне.
