Привет! Я использую RB532 с ОС версии 2.9.18, а настройки беспроводных интерфейсов (Senao на базе AR5213) следующие: / interface wireless set wlan2 name="wlan2" mtu=1500 arp=enabled disable-running-check=no mode=ap-bridge ssid="5" area="" frequency-mode=regulatory-domain country=poland antenna-gain=0 frequency=5540 band=5ghz scan-list=default rate-set=configured supported-rates-b="" supported-rates-a/g=6Mbps basic-rates-b="" basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=enabled periodic-calibration-interval=60 burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="IEEE 802.11a" disabled=yes set wlan1 name="wlan1" mtu=1500 arp=enabled disable-running-check=no mode=ap-bridge ssid="2" area="" frequency-mode=regulatory-domain country=poland antenna-gain=0 frequency=2442 band=2.4ghz-b/g scan-list=default rate-set=configured supported-rates-b=1Mbps supported-rates-a/g=6Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default periodic-calibration-interval=60 burst-time=disabled dfs-mode=no-radar-detect antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no comment="IEEE 802.11b/g" disabled=yes / interface wireless nstreme set wlan2 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200 set wlan1 enable-nstreme=no enable-polling=yes framer-policy=none framer-limit=3200 / interface wireless manual-tx-power-table set wlan2 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17 set wlan1 manual-tx-powers=1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17 / interface wireless security-profiles set default name="default" mode=dynamic-keys authentication-types=wpa-psk unicast-ciphers=tkip group-ciphers=tkip wpa-pre-shared-key="111111" wpa2-pre-shared-key="" tls-mode=no-certificates tls-certificate=none static-algo-0=none static-key-0="" static-algo-1=none static-key-1="" static-algo-2=none static-key-2="" static-algo-3=none static-key-3="" static-algo-4=none static-key-4="" static-algo-5=none static-key-5="" static-algo-6=none static-key-6="" static-algo-7=none static-key-7="" static-algo-8=none static-key-8="" static-algo-9=none static-key-9="" static-algo-10=none static-key-10="" static-algo-11=none static-key-11="" static-algo-12=none static-key-12="" static-algo-13=none static-key-13="" static-algo-14=none static-key-14="" static-algo-15=none static-key-15="" / interface wireless set wlan2 ssid="5" country=poland frequency=5540 frequency-mode=dynamic / interface wireless set wlan1 ssid="2" country=poland frequency=2442 frequency-mode=dynamic
Моя проблема в том, что я подключился к интерфейсу wlan1 (2.4GHz), но в логах постоянно появляются следующие сообщения:
wireless,info 00:12:F0:B6:4B:EC@wlan1: disconnected, got disassoc: unspecified (1)
Что может быть причиной этих логов?
Заранее благодарю за быстрый ответ.
Марк
Марк
