    Очередь 2.8 против 2.9.
    Очередь 2.8 против 2.9., RouterOS
    fatonk
    11.02.2006 15:16:00
    Привет! Кто-нибудь знает, как это нужно преобразовать в версию 2.9.6:
    ip firewall mangle add src-address=192.168.2.0/24 mark-flow=p2p-out p2p=all-p2p action=accept
    ip firewall mangle add dst-address=192.168.2.0/24 mark-flow=p2p-in p2p=all-p2p action=accept
    queue type add name=p2p-in kind=pcq pcq-rate=56000 pcq-classifier=src-address
    queue type add name=p2p-out kind=pcq pcq-rate=56000 pcq-classifier=dst-address
    queue tree add name=p2p-in parent=global-in flow=p2p-in queue=p2p-in priority=8
    queue tree add name=p2p-out parent=global-out flow=p2p-out queue=p2p-out priority=8
    ip firewall mangle add action=accept mark-flow=all
    queue type add name=PCQ-Down kind=pcq pcq-rate=131072 pcq-classifier=dst-address
    queue type add name=PCQ-Up kind=pcq pcq-rate=131072 pcq-classifier=src-address
    queue tree add parent=global-in queue=PCQ-Down flow=all priority=1
    queue tree add parent=global-out queue=PCQ-Up flow=all priority=1
    faton
    fatonk
    13.02.2006 10:07:00
    Это преобразование в 2.9.6. Разница в том, что в mangle нет src-address и dst-address, а родителями являются интерфейсы, протестировано OK: ip firewall mangle add chain=forward p2p=all-p2p action=mark-connection new-connection-mark=p2p_conn passthrough=yes ip firewall mangle add chain=forward connection-mark=p2p_conn action=mark-packet new-packet-mark=p2p passthrough=yes ip firewall mangle add chain=forward connection-mark=!p2p_conn action=mark-packet new-packet-mark=other passthrough=yes queue type add name=p2p-Down kind=pcq pcq-rate=56000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000 queue type add name=p2p-Up kind=pcq pcq-rate=56000 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=2000 queue type add name=Down kind=pcq pcq-rate=128000 pcq-limit=50 pcq-classifier=dst-address pcq-total-limit=2000 queue type add name=Up kind=pcq pcq-rate=128000 pcq-limit=50 pcq-classifier=src-address pcq-total-limit=2000 queue tree add name=p2p-up parent=WAN packet-mark=p2p limit-at=0 queue=p2p-Up priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s queue tree add name=p2p-Down parent=LAN packet-mark=p2p limit-at=0 queue=p2p-Down priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s queue tree add name=Upload parent=WAN packet-mark=other limit-at=0 queue=Up priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s queue tree add name=Download parent=LAN packet-mark=other limit-at=0 queue=Down priority=1 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s Regards, Faton
    tlkhorses
    12.03.2006 03:00:00
    На примере 2.9 выше я получаю ошибку на строке, где добавляется дерево очередей. Я предполагаю, что это связано с parent=WAN. Что-то должно быть вместо WAN? Похоже, это должен быть один из интерфейсов. Например, в беспроводном подключении точки доступа wlan1 будет LAN, а ether1 тоже будет LAN? tk
    fatonk
    12.03.2006 10:20:00
    Привет! WAN — это интерфейс, обращённый к общедоступной сети, а LAN — интерфейс, обращённый к локальной сети (клиентам). Например, WAN может быть интерфейсом ether1, подключённым к модему DSL, а LAN — это 2.4GHz интерфейс, к которому подключены клиенты.
    P.S. Я назвал свои интерфейсы WAN (общедоступный) и LAN (локальный).
    С уважением.
    tlkhorses
    14.03.2006 01:11:00
    Перепутал их. Спасибо за помощь. tk
    tlkhorses
    15.04.2006 01:57:00
    Еще пара вопросов по этому поводу. В версии 2.8 это использует родительский элемент global-in или global-out. А в версии 2.9 — конкретный интерфейс. Почему такая разница? Этот следующий вопрос кажется, что его где-то уже обсуждали много раз, но я не вижу четкого ответа. Похоже, эти правила не перехватывают UDP p2p. Я знаю, что UDP - это connectionless, так что есть ли другой способ? tk
