    Без интерфейсов — RouterOS x86 10G SFP+ Intel 82599EB
    Без интерфейсов — RouterOS x86 10G SFP+ Intel 82599EB, RouterOS
    bna
    25.09.2017 12:36:00
    Здравствуйте, у меня есть x86 RouterOS с 10G SFP+ сетевой картой Intel 82599EB. 10G-интерфейсы не отображаются в меню «Interface». Сетевая карта видна в списке pci устройств (строки 5 и 6):
    /system resource pci print detail
    0 device="05:05.0" name="82541GI Gigabit Ethernet Controller (rev: 5)" vendor="Intel Corporation" category="Ethernet controller" vendor-id="0x8086" device-id="0x1076" irq=10 memory=0x88220000-0x8823FFFF,0x88200000-0x882FFFFF io=0x1100-0x113F
    1 device="05:04.0" name="ES1000 (rev: 2)" vendor="ATI Technologies Inc" category="VGA compatible controller" vendor-id="0x1002" device-id="0x515e" irq=11 memory=0x80000000-0x87FFFFFF,0x88240000-0x8824FFFF io=0x1000-0x1FFF
    2 device="04:00.4" name="82573E KCS (Active Management) (rev: 3)" vendor="Intel Corporation" category="IPMI SMIC interface" vendor-id="0x8086" device-id="0x108e" irq=9 memory=0x883A0000-0x883A0FFF io=0x2028-0x202B
    3 device="04:00.3" name="Active Management Technology - SOL (rev: 3)" vendor="Intel Corporation" category="Serial controller" vendor-id="0x8086" device-id="0x108f" irq=11 memory=0x883A1000-0x883A1FFF io=0x2020-0x2027
    4 device="04:00.0" name="82573E Gigabit Ethernet Controller (Copper) (rev: 3)" vendor="Intel Corporation" category="Ethernet controller" vendor-id="0x8086" device-id="0x108c" irq=10 memory=0x88380000-0x8839FFFF,0x88300000-0x883FFFFF io=0x2000-0x2FFF
    5 device="01:00.1" name="82599EB 10-Gigabit Network Connection (rev: 1)" vendor="Intel Corporation" category="Ethernet controller" vendor-id="0x8086" device-id="0x10fb" irq=10 memory=0x88080000-0x880FFFFF,0x88104000-0x88107FFF io=0x3000-0x3FFF
    6 device="01:00.0" name="82599EB 10-Gigabit Network Connection (rev: 1)" vendor="Intel Corporation" category="Ethernet controller" vendor-id="0x8086" device-id="0x10fb" irq=9 memory=0x88000000-0x881FFFFF,0x88100000-0x88103FFF io=0x3020-0x303F
    7 device="00:1f.3" name="82801G (ICH7 Family) SMBus Controller (rev: 1)" vendor="Intel Corporation" category="SMBus" vendor-id="0x8086" device-id="0x27da" irq=11 io=0x4000-0x401F
    /interface print
    Flags: D - динамический, X - отключен, R - работает, S - подчинённый
    #     NAME                                TYPE       ACTUAL-MTU L2MTU  MAX-L2MTU MAC-ADDRESS
    0  R  ether5                              ether            1500  9014            00:15:17:24:EE:97
    1  R  ether6                              ether            1500                  00:15:17:24:EE:98
    2  R  bridge-pppoe-v503                   bridge           1500 65535            00:00:00:00:00:00
    3  R  bridge-pppoe-v507                   bridge           1500 65535            00:00:00:00:00:00
    4     v5_diamonds_eth4                    vlan                                   90:E2:BA:36:23:EF
    5     v12_test_eth3                       vlan                                   90:E2:BA:36:23:EE
    6  X  v26_ripe_probe_eth3                 vlan                                   00:00:00:00:00:00
    7     v502_internal_ospf_eth3             vlan                                   90:E2:BA:36:23:EE
    8     v503_phys_eth3                      vlan                                   90:E2:BA:36:23:EE
    9     v507_yur_eth3                       vlan                                   90:E2:BA:36:23:EE
    10     v809_pptp_eth3                      vlan                                   90:E2:BA:36:23:EE
    11     v809vrrp                            vrrp                                   00:00:5E:00:01:01
    ether5 и ether6 — встроенные интерфейсы.
    Версия RouterOS: 6.40.3
    Возможно, проблема из-за SFP-модулей. В Linux для модуля iggbe можно задать опцию «allow_unsupported_sfp». Как сделать это в RouterOS? Как узнать причину, почему интерфейсы не видны?
    vetash
    30.05.2019 13:37:00
    Ты нашёл решение этой проблемы? Я установил Intel X520 в сервер, а RouterOS видит только один интерфейс.
    r00t
    30.05.2019 14:27:00
    Многие последние драйверы не включены в x86 ROS, его давно не обновляли, и я не думаю, что это скоро изменится. Покупать железо, которое поддерживается, — всё равно что играть в русскую рулетку, ведь даже официального списка поддерживаемого оборудования нет. Есть небольшая надежда, что в ROS 7.x будет использоваться более современное ядро и появится больше драйверов, но всё это лишь домыслы, и никто не знает, когда эта версия выйдет, так что сейчас тебе просто не повезло. Единственный возможный вариант на данный момент — запускать гипervisор и CHR ROS, тратя процессорные ресурсы на виртуализацию, которая реально не нужна...
    kaktuss77
    15.11.2019 10:11:00
    Привет, могу подтвердить, что Intel X520-DA2 поддерживается в Mikrotik x86 версии 6.45.7 (stable), дата сборки: 24 октября 2019, 08:44:35. Эта сетевая карта Intel — OEM-версия, извлечённая из сервера Dell.
    # DEVICE   VENDOR                              NAME        IRQ
    1 01:00.1  Intel Corporation                82599EB 10-гигабитный сетевой адаптер (rev: 1)                 10
    2 01:00.0  Intel Corporation                82599EB 10-гигабитный сетевой адаптер (rev: 1)                 11
    r00t
    15.11.2019 14:33:00
    Хорошо, по крайней мере этот работает. К тому же в одном из других обсуждений мы получили информацию от Mikrotik, что в следующую бета-версию ROS 7 будет добавлено ещё больше драйверов Intel, так что, похоже, есть надежда…
    nazimkhan10172
    18.11.2020 12:21:00
    Привет! Я использую ту же карту на x86 с версией 6.45.9 stable, но сетевая карта не отображается. Не можешь ли ты выложить драйвер или подсказать способ, как запустить её?
    CyberDaeng
    08.04.2021 02:20:00
    Я тоже использую X520-DA2 в двух своих Border Router, и они работают идеально с v6.81. Вам ничего не нужно делать, устройство должно определяться автоматически.
