    Проблема v2.9beta16-18 EOIP-bridge
    Проблема v2.9beta16-18 EOIP-bridge, RouterOS
    teisik
    20.04.2005 10:00:00
    Проблема с eiop и bridge [admin@hksu] > interface print
    Flags: X - disabled, D - dynamic, R - running
    NAME                         TYPE             RX-RATE    TX-RATE    MTU
    0  R ether1                       ether            0          0          1500
    1  R ether2                       ether            0          0          1500
    2  R ether3                       ether            0          0          1500
    3  R bridge1                      bridge           0          0          1500
    4  R eoip-tunnel1                 eoip-tunnel      0          0          1500
    [admin@hksu] > [admin@hksu] > interface eoip print
    Flags: X - disabled, R - running
    0  R name=“eoip-tunnel1” mtu=1500 mac-address=FF:FD:40:00:00:00 arp=enabled remote-address=192.168.207.18 tunnel-id=19
    [admin@hksu] > [admin@hksu] > interface bridge print
    0  R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:04:06:E8 stp=yes priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s max-message-age=20s
    [admin@hksu] > [admin@hksu] > interface bridge port print
    INTERFACE    BRIDGE  PRIORITY PATH-COST
    0 ether1       none    128      10
    1 ether2       none    128      10
    2 ether3       bridge1 128      10
    3 eoip-tunnel1 bridge1 128      10
    [admin@hksu] > [admin@hksu] > interface bridge port monitor ether3
    status: forwarding
    port-id: 32769
    designated-root: 32768.00:0C:42:04:06:E8
    designated-bridge: 32768.00:0C:42:04:06:E8
    designated-port: 32769
    designated-cost: 0
    [admin@hksu] > [admin@hksu] > interface bridge port monitor eoip-tunnel1
    status: disabled
    port-id: 0
    designated-root: 0.00:00:00:00:00:00
    designated-bridge: 0.00:00:00:00:00:00
    designated-port: 0
    designated-cost: 0
    eoip bridge port status disabled ? how I can enabe this ?
    jober
    22.04.2005 15:14:00
    Не уверен, поможет ли это, потому что EoIP-туннели, которые я запускаю, объединены. У меня есть два MT, которые объединяют 2 ADSL-линии. Настройка такая: [admin@ClientBonder] > interface bonding print Flags: X - disabled, R - running 0 R name=“bonding1” mtu=1500 mac-address=FE:FD:00:00:00:03 arp=enabled slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none link-monitoring=arp arp-interval=100ms arp-ip-targets=xxx.xxx.xxx.xxx mii-interval=100ms down-delay=0s up-delay=0s lacp-rate=30secs [admin@ClientBonder] > interface bridge print Flags: X - disabled, R - running 0 R name=“bridge1” mtu=1500 arp=enabled mac-address=00:0C:42:02:19:E7 stp=no priority=32768 ageing-time=5m forward-delay=15s garbage-collection-interval=5s hello-time=2s max-message-age=20s
    Я знаю, что мне следовало бы использовать маршрутизацию, но я не хочу заморачиваться с этим, потому что переезжаю из дома на тестовые площадки. Добавлю маршрутизацию после того, как все сценарии сбоев и настройки будут доведены до автоматизма, как часы. Также не знаю, что произойдет, когда я подключу это к кабельной линии и ADSL-линии. Думаю, что разные размеры каналов все испортят.
    hitek146
    30.04.2005 10:45:00
    У меня работает EoIP-туннель через PPTP-туннель между двумя беспроводно подключенными RB532, и все отлично… Просто посмотрел на MAC-адреса твоего EoIP-интерфейса, и вижу, что они не попадают в диапазоны от 00-00-5E-80-00-00 до 00-00-5E-FF-FF-FF, возможно, в этом проблема… Смотри 3-е "Примечание" здесь: http://www.mikrotik.com/docs/ros/2.8/interface/eoip.content#5.19.2.3 Hitek Edit: Еще раз посмотрел, и оказывается, что это просто доступные MAC-адреса…
