Я не могу понять, почему не удаётся подключиться к MSN Messenger. Я смотрел форум, но не нашёл там решения своей проблемы. Если логин и пароль верны, то мессенджер сообщает об ошибке аутентификации, а если они правильные — просто не подключается. Вот правила брандмауэра…
INPUT [admin@TheBoneRouter]
ip firewall rule input> pr
Flags: X - disabled, I - invalid, D - dynamic
0 ;;; Drop invalid connection packets
connection-state=invalid action=drop
1 ;;; Allow established connections
connection-state=established action=accept
2 ;;; Allow related connections
connection-state=related action=accept
3 ;;; Allow UDP connections
protocol=udp action=accept
4 ;;; Allow ICMP messages
protocol=icmp action=accept
5 ;;; Allow access from ‘trusted’ network
src-address=192.168.0.0/24 action=accept
6 ;;; Allow access from ‘trusted’ network
src-address=192.168.2.0/24 action=accept
7 ;;; Allow access from ‘trusted’ network
src-address=192.168.3.0/24 action=accept
8 ;;; Allow access from ‘trusted’ network
src-address=192.168.1.0/24 action=accept
9 ;;; Allow access from ‘trusted’ network
src-address=192.168.4.0/24 action=accept
10 ;;; Reject and log everything else
action=drop log=yes
FORWARD [admin@TheBoneRouter]
ip firewall rule forward> pr
3 ;;; Allow ICMP ping packets
out-interface=pppoe-out1 protocol=icmp action=accept
4 ;;; Allow outgoing connections from the server at 192.168.x.x
src-address=192.168.2.100/32 out-interface=pppoe-out1 action=accept
5 src-address=192.168.2.160/32 out-interface=pppoe-out1 action=accept
6 src-address=192.168.0.180/32 out-interface=pppoe-out1 action=accept
7 src-address=192.168.0.181/32 out-interface=pppoe-out1 action=accept
8 src-address=192.168.0.182/32 out-interface=pppoe-out1 action=accept
9 src-address=192.168.0.190/32 out-interface=pppoe-out1 action=accept
10 src-address=192.168.0.191/32 out-interface=pppoe-out1 action=accept
11 src-address=192.168.0.150/32 out-interface=pppoe-out1 action=accept
12 src-address=192.168.0.141/32 out-interface=pppoe-out1 action=accept
13 src-address=192.168.0.140/32 out-interface=pppoe-out1 action=accept
14 src-address=192.168.2.101/32 out-interface=pppoe-out1 action=accept
15 src-address=192.168.2.102/32 out-interface=pppoe-out1 action=accept
16 ;;; Drop and log everything else
out-interface=pppoe-out1 action=drop log=yes
src-nat [admin@TheBoneRouter]
ip firewall src-nat> pr
0 out-interface=pppoe-out1 action=masquerade
dst-nat [admin@TheBoneRouter]
ip firewall dst-nat> pr
0 ;;; Web PROXY port 3x
in-interface=ether1 dst-address=!192.168.0.1/32:80 protocol=tcp action=redirect to-dst-port=8080
1 in-interface=ether2 dst-address=!192.168.2.1/32:80 protocol=tcp action=redirect to-dst-port=8080
2 in-interface=ether3 dst-address=!192.168.4.1/32:80 protocol=tcp action=redirect to-dst-port=8080
3 ;;; Porti Chris TCP
in-interface=pppoe-out1 dst-address=:22000-22001 protocol=tcp action=nat to-dst-address=192.168.0.140
4 ;;; Porti Chris UDP
in-interface=pppoe-out1 dst-address=:22000-22001 protocol=udp action=nat to-dst-address=192.168.0.140
5 ;;; Porti Logar TCP
in-interface=pppoe-out1 dst-address=:7000-7003 protocol=tcp action=nat to-dst-address=192.168.0.180
6 ;;; Porti Logar UDP
in-interface=pppoe-out1 dst-address=:7000-7003 protocol=udp action=nat to-dst-address=192.168.0.180
7 ;;; Porti dusi TCP
in-interface=pppoe-out1 dst-address=:3000-3004 protocol=tcp action=nat to-dst-address=192.168.2.100
8 ;;; Porti dusi UDP
in-interface=pppoe-out1 dst-address=:3000-3004 protocol=udp action=nat to-dst-address=192.168.2.100
9 D dst-address=213.250.60.61/32:20204 protocol=udp action=nat to-dst-address=192.168.2.101 to-dst-port=11907
10 D dst-address=213.250.60.61/32:49630 protocol=tcp action=nat to-dst-address=192.168.2.101 to-dst-port=7180
11 D dst-address=193.77.133.93/32:59619 protocol=tcp action=nat to-dst-address=192.168.2.102 to-dst-port=8486
Я бы очень нуждался в помощи в этом вопросе.
Спасибо,
Christian
action=drop log=yes
Спасибо,
Christian
