Я вижу новый функционал. Пришлось удалить пакет маршрутизации, удалить routing-test, перезагрузить систему и переустановить routing-test. Вот что я вижу для тех, кто сейчас не может загрузить новый пакет routing-test: routing bgp instance
routing bgp instance add as= router-id= redistribute-static= redistribute-connected= redistribute-rip= redistribute-ospf= redistribute-other-bgp= name= out-filter= copy-from= disabled=
routing bgp instance disable <numbers>
routing bgp instance edit <number> <value-name>
routing bgp instance enable <numbers>
routing bgp instance export file= from=
routing bgp instance find as= router-id= redistribute-static= redistribute-connected= redistribute-rip= redistribute-ospf= redistribute-other-bgp= name= out-filter= from= disabled=
routing bgp peer get <number> <value-name>
routing bgp peer print without-paging count-only append value-list terse detail brief interval= file= out-filter= from=
routing bgp instance remove <numbers>
routing bgp instance set <numbers> as= router-id= redistribute-static= redistribute-connected= redistribute-rip= redistribute-ospf= redistribute-other-bgp= name= out-filter= disabled=
routing bgp peer
routing bgp peer add remote-address= remote-as= multihop= in-filter= out-filter= keepalive-time= hold-time= instance= ttl= copy-from= disabled=
routing bgp peer disable <numbers>
routing bgp peer edit <number> <value-name>
routing bgp peer enable <numbers>
routing bgp peer export file= from=
routing bgp peer find remote-address= remote-as= multihop= in-filter= out-filter= keepalive-time= hold-time= instance= ttl= remote-id= remote-hold-time= used-hold-time= used-keepalive-time= state= from= disabled=
routing bgp peer print without-paging count-only append stats value-list terse detail brief interval= file= in-filter= out-filter= instance= state= from=
routing bgp peer remove <numbers>
routing bgp peer set <numbers> remote-address= remote-as= multihop= in-filter= out-filter= keepalive-time= hold-time= instance= ttl= disabled=
routing filter add set-disabled chain= prefix= prefix-length= match-chain= type= preference= scope= target-scope= prefsrc= routing-mark= comment= origin= med= local-pref= atomic-aggregate= as-path= action= jump-target= set-preference= set-scope= set-target-scope= set-prefsrc= set-nexthop= set-routing-mark= set-check-gateway= set-comment= set-med= set-localpref= set-prepend= unset= copy-from= place-before= comment= disabled=
routing filter comment <numbers> <comment>
routing filter disable <numbers>
routing filter edit <number> <value-name>
routing filter enable <numbers>
routing filter export file= from=
routing filter find set-disabled chain= prefix= prefix-length= match-chain= type= preference= scope= target-scope= prefsrc= routing-mark= comment= origin= med= local-pref= atomic-aggregate= as-path= action= jump-target= set-preference= set-scope= set-target-scope= set-prefsrc= set-nexthop= set-routing-mark= set-check-gateway= set-comment= set-med= set-localpref= set-prepend= unset= from= comment= disabled=
routing filter get <number> <value-name>
routing filter move <numbers> <destination>
routing filter print without-paging count-only append value-list terse detail brief interval= file= chain= jump-target= set-check-gateway= from=
routing filter remove <numbers>
routing filter set <numbers> set-disabled chain= prefix= prefix-length= match-chain= type= preference= scope= target-scope= prefsrc= routing-mark= comment= origin= med= local-pref= atomic-aggregate= as-path= action= jump-target= set-preference= set-scope= set-target-scope= set-prefsrc= set-nexthop= set-routing-mark= set-check-gateway= set-comment= set-med= set-localpref= set-prepend= unset= comment= disabled=
routing filter unset <numbers> <value-name> Поддержки Winbox пока нет, и документации тоже, но уверен, что она появится. Спасибо, ребята! Sam
