    Полоса пропускания канала связи.
    Полоса пропускания канала связи., RouterOS
    kokopelli
    25.01.2005 20:36:00
    Привет! Сможет ли Atheros радио на 5 ГГц обеспечить достаточную пропускную способность на расстоянии 25 км для передачи 4 Т1-канала? Спасибо.
    mip
    26.01.2005 14:32:00
    Искать. Я прочитал, этого достаточно, но тебе стоит поискать информацию о длинных связях где-то здесь.
    ofasa
    27.01.2005 12:31:00
    http://www.mikrotik.com/forum/viewtopic.php?t=1906
    Hey guys,
    Just wanted to share a quick workaround I found for getting VLANs to work on older Mikrotik routers (v2, v3) that are struggling with the native VLAN tag on bridges.
    So, I'm running a bunch of these older routers as access points, and I wanted to allow my VLAN tagged traffic to pass through them without having to upgrade the firmware. Turns out, you can use a simple route to achieve this.
    Here’s the setup:
    1.  Create a VLAN interface.
    2.  Assign an IP address to the VLAN interface.
    3.  Create a static route with the destination being the VLAN network and the gateway being the VLAN interface.
    That's it! It's surprisingly effective.  I was skeptical at first, but it's been working flawlessly for me.
    Just thought I'd share this little trick in case anyone else is dealing with similar limitations.
    Cheers!
    #mikrotik #vlan #workaround
