    Точка доступа, файрвол.
    Точка доступа, файрвол., RouterOS
    ddlan
    24.05.2005 14:57:00
    Привет, Konfiguration: DSL динамический адрес → Роутер → Mikrotik (ether1) IP Pool → Mikrotik (ether2) Mikrotik PPPoE Server (ether3) Mirkotik Konfiguration: / interface ethernet set “DSL (ether1)” name=“DSL (ether1)” mtu=1500 mac-address=00:90:27:8F:35:55 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no set “static (ether2)” name=“static (ether2)” mtu=1500 mac-address=00:02:B3:40:15:88 arp=proxy-arp disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no set “DDLAN (ether3)” name=“DDLAN (ether3)” mtu=1500 mac-address=00:07:E9:A8:0B:38 arp=enabled disable-running-check=yes auto-negotiation=yes full-duplex=yes cable-settings=default speed=100Mbps comment=“” disabled=no / interface bridge port set “DSL (ether1)” bridge=none priority=128 path-cost=10 set “static (ether2)” bridge=none priority=128 path-cost=10 set ether3 bridge=none priority=128 path-cost=10 set ether4 bridge=none priority=128 path-cost=10 set “DDLAN (ether3)” bridge=none priority=128 path-cost=10 add service-name=“ddlan” interface=“DDLAN (ether3)” max-mtu=1480 max-mru=1480 authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=yes max-sessions=0 default-profile=default disabled=no / ip address add address=xx.xx.xx.194/26 network=xx.xx.xx.192 broadcast=xx.xx.xx.255 interface=“static (ether2)” comment=“” disabled=no add address=172.16.0.2/16 network=172.16.0.0 broadcast=172.16.255.255 interface=“DDLAN (ether3)” comment=“” disabled=no add address=192.168.102.1/24 network=192.168.102.0 broadcast=192.168.102.255 interface=“DSL (ether1)” comment=“” disabled=no / ip route add dst-address=0.0.0.0/0 gateway=xx.xx.xx.193 distance=1 scope=255 target-scope=10 comment=“” disabled=no add dst-address=0.0.0.0/0 gateway=192.168.102.254 distance=1 scope=255 target-scope=10 routing-mark=PPPoE comment=“” disabled=no / ip pool add name=“static” ranges=xx.xx.xx.196-xx.xx.xx.254 add name=“PPPoE dyn” ranges=192.168.0.2-192.168.0.254 / ppp profile set default name=“default” use-compression=no use-vj-compression=no use-encryption=no only-one=yes change-tcp-mss=yes comment=“” add name=“static” local-address=192.168.0.1 remote-address=“static” use-compression=yes use-vj-compression=yes use-encryption=yes only-one=yes change-tcp-mss=yes comment=“” add name=“DSL NAT” local-address=192.168.0.1 remote-address=“PPPoE dyn” use-compression=yes use-vj-compression=yes use-encryption=yes only-one=yes change-tcp-mss=yes comment=“” add name=“default-encryption” use-compression=default use-vj-compression=default use-encryption=yes only-one=yes change-tcp-mss=yes comment=“” / interface pppoe-server server add service-name=“ddlan” interface=“DDLAN (ether3)” max-mtu=1480 max-mru=1480 authentication=pap,chap,mschap1,mschap2 keepalive-timeout=10 one-session-per-host=yes max-sessions=0 default-profile=default disabled=no / ip firewall mangle add chain=prerouting src-address=192.168.0.0/24 dst-address=0.0.0.0/0 action=mark-routing new-routing-mark=PPPoE comment=“” disabled=no This koniguration works fine for both PPP Profiles. Когда добавляешь: / ip firewall filter add chain=forward src-address=192.168.0.0/24 action=accept comment=“” disabled=no add chain=forward src-address=xx.xx.xx.192/26 action=accept comment=“” disabled=no add chain=forward action=drop comment=“” disabled=yes, то профиль “DSL NAT” работает, а у профиля “static” нет переадресации от PPPoE-Server в Интернет. Есть какие-нибудь подсказки? Спасибо, Томас Бётчер P.S. извините за мой английский
    ddlan
    25.05.2005 13:27:00
    Привет, ответ:
    / ip firewall filter add chain=forward action=jump jump-target=static comment=“” disabled=no
    add chain=forward action=drop comment=“” disabled=no
    add chain=static src-address=xx.xx.xx.192/26 action=accept comment=“” disabled=no
    add chain=static dst-address=xx.xx.xx.192/26 action=accept comment=“” disabled=no
    mfg Thomas Böttcher
