    Помогите с nstreme2, пожалуйста!!!!!
    Помогите с nstreme2, пожалуйста!!!!!, RouterOS
    Sergioz
    07.11.2005 20:17:00
    Помогите, пожалуйста, срочно настроить Nstreme-Dual. У меня 2 RB500 с 2 AR5413 на каждой плате RB500. Я очень строго следовал документации, настраивал Nstreme-Dual шаг за шагом. Конфигурация следующая:
    Плата 1: admin@MikroTik] interface wireless>
    name=“wlan1” mtu =1500 mac-address=00:11:F5:60:0B:EB arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600BEB” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
    1
    name=“wlan2” mtu=1500 mac-address=00:11:F5:60:0C:A5 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600CA5” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
    Конфигурация Nstreme-Dual для платы 1:
    Flags: X - отключено, R - работает
    0 R name=“nstreme1” mtu=1500 mac-address=00:11:F5:60:0C:A5 arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:11:F5:60:0A:6D tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5320 rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps framer-policy=exact-size framer-limit=2560
    Плата 2: admin@MikroTik] interface wireless>
    name=“wlan1” mtu =1500 mac-address=00:11:F5:60:0A:79 arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600BEB” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
    1
    name=“wlan2” mtu=1500 mac-address=00:11:F5:60:0A:6D arp=enabled disable-running-check=no interface-type=Atheros AR5413 radio-name=“0011F5600CA5” mode=nstreme-dual-slave ssid=“MikroTik” area=“” frequency-mode=manual-txpower country=no_country_set antenna-gain=0 frequency=5180 band=5ghz scan-list=default rate-set=default supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps, 54Mbps basic-rates-b=1Mbps basic-rates-a/g=6Mbps max-station-count=2007 ack-timeout=dynamic tx-power-mode=default noise-floor-threshold=default periodic-calibration=default burst-time=disabled dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
    Конфигурация Nstreme-Dual для платы 2:
    0 R name=“nstreme1” mtu=1500 mac-address=00:11:F5:60:0A:6D arp=enabled disable-running-check=no tx-radio=wlan1 rx-radio=wlan2 remote-mac=00:11:F5:60:0C:A5 tx-band=5ghz tx-frequency=5180 rx-band=5ghz rx-frequency=5320 rates-b=1Mbps ,2Mbps,5.5Mbps,11Mbps rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps framer-policy=exact-size framer-limit=2560
    Но при мониторинге интерфейса Nstreme-Dual на любой плате получаю следующее:
    eme-dual> monitor
    0 rx-signal-strength: -95dBm tx-signal-strength: -95dBm rx-rate: 1Mbps tx-rate: 6Mbps connected: no
    Я перепробовал разные Atheros карты, AR5213, но результат тот же!!! Помогите, пожалуйста, не вижу, где допустил ошибку, и очень переживаю из-за этого, так как это моя первая попытка настроить Nstreme2, и мне нужно настроить соединение к среде в среду на этой неделе!!!
    jonbrewer
    07.11.2005 20:57:00
    Ты собирал эти устройства сам, или взял готовые от Mikrotik? Если собирал, попробуй переключить режим антенны с ant-a на ant-b, может, поможет.
    Sergioz
    07.11.2005 21:10:00
    Мне прислали оборудование от MT, но не собрано (RoutedBoard500, OudoorBox, POE…). Я поменял режим антенны, но результат тот же: не подключается!! Есть еще какие-нибудь идеи, пожалуйста! Помогите разобраться, что происходит!! Это моя конфигурация? Мои Atheros карты (новые карты даже не использовались!!)? Моя плата? (новая плата уже использовалась)
    titius
    08.11.2005 12:22:00
    Я никогда не пользовался nstreme, но думаю, что одно из двух плат должна быть мастер-узел…
    uldis
    08.11.2005 12:28:00
    Пожалуйста, ещё раз прочитай документацию, ты указал неверные частоты. Должно быть так: RX-freq_board1=TX-freq_board2 TX-freq_board1=RX-freq_board2
    msolis
    08.11.2005 14:13:00
    Не используй одну и ту же частоту для передачи и приёма.
    uldis
    08.11.2005 16:31:00
    Похоже, ты не понял, что я написал в последнем сообщении. Частота RX на плате1 должна быть равна частоте TX на плате2, а частота TX на плате1 должна быть равна частоте RX на плате2.
    msolis
    08.11.2005 17:53:00
    Прости за ошибку. Действительно, Серхио использует разные частоты (5180 для передачи и 5320 для приема).
    psolano
    08.11.2005 17:58:00
    Один и тот же SSID не используй для приёмной и передающей карты.
