Всем привет! Помогите, пожалуйста, с контейнерами и маршрутизацией трафика на роутере. У меня Mikrotik hAP ax3 с USB-флешкой для хранения, на роутере установлены контейнеры AdguardHome, Xray-core и Tun2Socks. Конфигурация:
/interface bridge
add name=Dockers port-cost-mode=short
/interface veth
add address=10.6.0.2/24 gateway=10.6.0.1 gateway6="" name=VETH1-adguard
add address=10.6.0.3/24 gateway=10.6.0.1 gateway6="" name=VETH2-xray
add address=10.6.0.4/24 gateway=10.6.0.1 gateway6="" name=VETH3-tun
/interface list
add name=LANs
add name=WANs
/container
add interface=VETH1-adguard root-dir=usb1-part1/Containers/adguard start-on-boot=yes workdir=/opt/adguardhome/work
add dns=10.6.0.2 interface=VETH2-xray root-dir=usb1-part1/Containers/xray-core start-on-boot=yes workdir=/root
add dns=10.6.0.2 interface=VETH3-tun root-dir=usb1-part1/Containers/tun2socks start-on-boot=yes
/container config
set ram-high=250.0MiB registry-url=https://ghcr.io tmpdir=usb1-part1/TMP
/interface bridge port
add bridge=Dockers interface=VETH1-adguard
add bridge=Dockers interface=VETH2-xray
add bridge=Dockers interface=VETH3-tun
/interface list member
add interface=Bridge list=LANs
add interface=WAN list=WANs
/ip address
add address=10.10.12.1/24 interface=Bridge network=10.10.12.0
add address=10.6.0.1/24 interface=Dockers network=10.6.0.0
/ip dhcp-server network
add address=10.10.12.0/24 dns-server=10.6.0.2 gateway=10.10.12.1 netmask=24
/ip dns
set allow-remote-requests=yes cache-max-ttl=1w3d doh-timeout=6s query-server-timeout=2s500ms query-total-timeout=12s servers=1.1.1.1 use-doh-server=https://cloudflare-dns.com/dns-query verify-doh-cert=yes
/ip firewall filter
add action=fasttrack-connection chain=forward comment="Rule 1.0 Fasttrack" connection-state=established,related hw-offload=yes in-interface=Bridge out-interface=WAN
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes in-interface=WAN out-interface=Bridge
add action=accept chain=forward comment="Rule 1.0.1 Forward input established/related acept" connection-state=established,related,untracked log-prefix="Forward accept"
add action=accept chain=input connection-state=established,related,untracked log-prefix="Input accept"
add action=drop chain=forward comment="Rule 1.0.2 Forward input invalid drop" connection-state=invalid in-interface=WAN log-prefix="Forward drop invalid"
add action=drop chain=input connection-state=invalid in-interface=WAN log-prefix="Input drop invalid"
add action=drop chain=input comment="Rule 1.2.1 Input drop from WAN" in-interface-list=WANs log-prefix="Input all drop from WAN"
/ip firewall mangle
add action=mark-routing chain=prerouting dst-address=10.6.0.2 new-routing-mark=proxy_mark passthrough=yes src-address=10.10.12.52
/ip firewall nat
add action=dst-nat chain=dstnat comment="NAT 1.01 - TCP 53 Redirect DNS requests to AdguardHome" dst-port=53 in-interface=Bridge protocol=tcp to-addresses=10.6.0.2
add action=dst-nat chain=dstnat comment="NAT 1.02 - UDP 53 Redirect DNS requests to AdguardHome" dst-port=53 in-interface=Bridge protocol=udp to-addresses=10.6.0.2
add action=masquerade chain=srcnat comment="Containers through NAT" out-interface=WAN src-address=10.6.0.0/24
add action=masquerade chain=srcnat comment="WWW through VPN" dst-address-list=rkn_wg out-interface=WG1-VPS
add action=masquerade chain=srcnat comment="LAN through NAT" out-interface=WAN src-address=10.10.12.2-10.10.12.254
/routing table
add disabled=no fib name=wg_mark
add disabled=no fib name=proxy_mark
/ip route
add comment="Access to WWW through Proxy" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=10.6.0.4 pref-src="" routing-table=proxy_mark scope=30 suppress-hw-offload=yes target-scope=10
add comment="Access to WWW through WG1-VPS" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=WG1-VPS pref-src="" routing-table=wg_mark scope=30 suppress-hw-offload=yes target-scope=10
Контейнер AdguardHome работает без вопросов, все устройства в сети получают его как DNS-сервер через DHCP. Контейнер Xray-core (клиент к VPS-серверу с установленным 3X-UI) — после запуска контейнер останавливается, я редактирую файл config.json (там указаны настройки подключения). Всё работает нормально, он соединяется с VPS через XLTS+Reality, с локального ПК (Windows) и виртуальной машины (Ubuntu) при указании я спокойно выхожу в Интернет через Socks.
Вся загвоздка в контейнере Tun2Socks. Для запуска я скачал образ с github, потом запустил контейнер, остановил его и отредактировал entrypoint.sh:
#!/bin/sh
ip tuntap add mode tun dev tun0
ip addr add 198.18.0.1/15 dev tun0
ip link set dev tun0 up
ip route del default
ip route add default via 198.18.0.1 dev tun0 metric 1
ip route add default via 10.6.0.1 dev eth0 metric 10
tun2socks -device tun0 -proxy socks5://10.6.0.3:30804 -interface eth0
run || exit 1
Интернет из контейнеров работает (проверял и Xray-core, и Tun2Socks). Но когда пытаюсь отправить весь трафик с локального устройства из локальной сети в туннель (через правило mangle с отметкой proxy_mark), интернет совсем не работает — пинг и трассировка не проходят через туннель ни на какой сайт. При этом при такой же настройке для WireGuard всё работает и интернет доступен на всех устройствах.
Я сам вообще не спец по Unix-системам, с микротиком тоже долго разбирался. Не могу понять, в чём проблема — в туннеле или в настройках маршрутизации на роутере? Или, может, кто-то знает более простой способ?
/interface bridge
/interface veth
/interface list
add name=LANs
add name=WANs
/container
/container config
/ip address
/ip dns
/ip firewall filter
/ip firewall mangle
/ip firewall nat
/routing table
/ip route
#!/bin/sh
run || exit 1
