Hi all, I have a RB3011 with ROS7.5 running as an edge router. Behind it is a pfsense FW via a transit vlan (172.16.100.0/24), and behind that FW, a mail server on one of the PFsense’s legs (mailserver=172.16.15.11). The Mikrotik does the NAT-ing between the internal 172.16.0.0/12 networks and the public internet. It looks like this (well, it looks fancier in real life): (Internet)----Mikrotik-----Pfsense-----Mailserver In order to be completely honest, I wanted to be completely transparent by telling you that there is indeed a Pfsense FW in between, but please don’t point it to be the responsible device: this FW has been in place (with different upgrades of course) for 15+ years the mail server has been in place for 15+ years (also with upgrades of course) all that has changed now is the edge router as I am migrating from Cisco (+ WAN link behind it) to Mikrotik (+new WAN link behind it). the workaround I have put in place (see below) and packet captures (also see below) put the PFsense out of cause. Now to my issue. Oubound mails work perfectly (from our server to the outside world). However, we are unable to receive mails from outside with simple DST-NAT (with the old cisco it worked flawlessly), that is what makes me wonder). I am pretty sure there is an additional FW rule that needs to be set on the MT, but I can’t figure out which… As a temp workaround, I had to implement DST-NAT and SRC-NAT on the mikrotik. It works in terms of receiving emails, however, this is not a viable solution as the mail server sees all inbound mails coming from the MT’s LAN IP, which means that the IP-based ACL’s (for mitigating brute-force attacks) had to be deactivated and most spam filters are also useless now. Here’s what is currently in place: /ip firewall filter
add action=accept chain=forward comment="INBOUND SMTP" dst-address=172.16.15.11 dst-port=25 in-interface=WAN_ISP protocol=tcp
/ip firewall nat
add action=dst-nat chain=dstnat comment=SMTP dst-address=<PUBLIC_IP> dst-port=25 in-interface=WAN_ISP protocol=tcp to-addresses=172.16.15.11 to-ports=25
add action=src-nat chain=srcnat dst-address=172.16.15.11 dst-port=25 protocol=tcp to-addresses=172.16.100.2 the last line from the config above (src-nat) is the one I configured as a workaround, but which I need to get rid of asap in order to reactivate the ACL’s and spam filters. 172.16.100.2 is the Mikrotik IP on the transit VLAN to the Pfsense Now, here are 2 packet captures on the FW (on the 172.16.100.0/24 transit VLAN from the MT), both times for an inbound mail coming from the internet: without the SRC-NAT rule ( I replaced the external’s server IP with 1.1.1.1 as it is a client’s server…): 1.1.1.1.36610 > 172.16.15.11.25: tcp 0
172.16.15.11.25 > 1.1.1.1.36610: tcp 0
172.16.15.11.25 > 11.1.1.1.36610: tcp 0
172.16.15.11.25 > 1.1.1.1.36610: tcp 0 with the SRC-NAT rule (172.16.100.2 is the MT’s Transit interface IP) 172.16.100.2.44218 > 172.16.15.11.25: tcp 0
172.16.15.11.25 > 172.16.100.2.44218: tcp 0
172.16.15.11.25 > 172.16.100.2.44218: tcp 28
172.16.100.2.44218 > 172.16.15.11.25: tcp 27
172.16.15.11.25 > 172.16.100.2.44218: tcp 73
172.16.100.2.44218 > 172.16.15.11.25: tcp 35
172.16.15.11.25 > 172.16.100.2.44218: tcp 8
172.16.100.2.44218 > 172.16.15.11.25: tcp 34
172.16.100.2.44218 > 172.16.15.11.25: tcp 6
172.16.15.11.25 > 172.16.100.2.44218: tcp 15
172.16.100.2.44218 > 172.16.15.11.25: tcp 1440
172.16.100.2.44218 > 172.16.15.11.25: tcp 784
.... Could you help me out and help me find the rule which I guess is missing on the MT so that the mail reception could work? Thanks a lot! Denis
/ip firewall nat
2) Capture with only DST-NAT on the Mikrotik: Here, what is really, really weird is that we see the SYN request from the client, followed by the SYN, ACK from the server (which validates routing is OK, otherwise the packet would have been dropped), but then, the MT never sends the final ACK to the server, so we get into TCP retransmits until the request times out:
