Рад, что тебе кажется это хорошей идеей. Вот конфигурация.
# may/19/2024 16:50:20 by RouterOS 7.4
# software id = 8E98-BRCA
# model = RBGrooveGA-52HPacn
# serial number = serialnumber
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4 use-network-apn=no
add authentication-types=wpa2-psk management-protection=allowed mode=dynamic-keys name=Home supplicant-identity=MikroTik
add authentication-types=wpa2-psk mode=dynamic-keys name="WAN wifi" supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac country="new zealand" disabled=no frequency=5260 installation=outdoor security-profile="WAN wifi" ssid="ssid of WAN wifi"
/ip pool
add name=dhcp ranges=192.168.0.10-192.168.0.254
/ip dhcp-server
add address-pool=dhcp interface=ether1 name=defconf
/ip neighbor discovery-settings
set discover-interface-list=LAN
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=8192
/interface list member
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=wlan1 list=WAN
add list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=192.168.4.1/32,192.168.4.8/32,0.0.0.0/0 endpoint-address=my.wan.ip.address endpoint-port=51820 interface=wireguard1 public-key="publicKeyObfuscated="
/ip address
add address=192.168.0.1/24 comment=defconf interface=ether1 network=192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.50 client-id=1:b8:27:eb:ab:43:a7 mac-address=B8:27:EB:AB:43:A7 server=defconf
add address=192.168.0.51 client-id=1:e4:5f:1:8b:7a:76 mac-address=E4:5F:01:8B:7A:76 server=defconf
add address=192.168.0.52 client-id=1:e4:5f:1:f8:56:e9 mac-address=E4:5F:01:F8:56:E9 server=defconf
/ip dhcp-server network
add address=192.168.0.0/24 comment=defconf gateway=192.168.0.1 netmask=24
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
/ip firewall filter
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
/tool mac-server
set allowed-interface-list=LAN
/tool mac-server mac-winbox
Unifi UDM Pro настроен с сервером Wireguard, который отлично работает с другими клиентами (устройствами за этим роутером Mikrotik и с других локаций). В идеале я бы хотел, чтобы GrooveGA поддерживал VPN site-to-site с сетью Unifi, чтобы не нужно было держать прямые VPN-подключения с устройств на стороне Mikrotik. Если это невозможно, то хотя бы чтобы GrooveGA мог подключаться к VPN, чтоб я мог удалённо заходить в конфигурацию — и это было бы нормально. Я не контролирую wifi-WAN, к которому подключён GrooveGA, поэтому не могу настроить удалённый доступ без VPN — и предпочёл бы не проксировать трафик через одно из устройств, подключённых к VPN.
Сеть GrooveGA — 192.168.1.0/24
Сеть UDM — 192.168.1.1/24
Если чего-то не хватает — буду очень признателен за советы.
