Я обновил оба Mikrotik HAP AC2 до последней стабильной версии (6.48.1). Вот соответствующая конфигурация в Mikrotik Site1 (Штаб-квартира):
/interface bridge add name=blankbridge1
/interface gre add local-address=192.168.99.1 name=gre-tunnel1 remote-address=192.168.99.2
/ip ipsec mode-config add address=192.168.99.2 address-prefix-length=32 name=cfg1 split-include=192.168.99.1/32
/ip ipsec policy group add name=group1
/ip ipsec profile add dh-group=modp1024 enc-algorithm=aes-128 lifetime=8h name=profile1
/ip ipsec peer add name=peer1 passive=yes profile=profile1 send-initial-contact=no
/ip ipsec proposal add enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=8h name=proposal1 pfs-group=none
/ip ipsec identity add auth-method=pre-shared-key-xauth generate-policy=port-strict mode-config=cfg1 password=blablabla peer=peer1 policy-template-group=group1 secret=blablapsk username=user1
/ip ipsec policy add dst-address=192.168.99.2/32 group=group1 proposal=proposal1 src-address=192.168.99.1/32 template=yes
/ip route add distance=1 dst-address=192.168.9.0/24 gateway=172.16.1.2
/ip address add address=192.168.99.1 interface=blankbridge1 network=192.168.99.1
/ip address add address=192.168.8.1/24 comment=defconf interface=bridge network=192.168.8.0
/ip address add address=172.16.1.1/30 interface=gre-tunnel1 network=172.16.1.0
/ip firewall filter add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
/ip firewall filter add action=accept chain=input protocol=ipsec-esp
/ip firewall filter add action=accept chain=input protocol=gre
/ip firewall filter add action=accept chain=input dst-port=500,4500 in-interface-list=WAN protocol=udp
/ip firewall filter add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!LAN
/ip firewall filter add action=accept chain=forward comment="defconf: accept in ipsec policy" ipsec-policy=in,ipsec
/ip firewall filter add action=accept chain=forward comment="defconf: accept out ipsec policy" ipsec-policy=out,ipsec
/ip firewall filter add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
/ip firewall filter add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=established,related,untracked
/ip firewall filter add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid
/ip firewall filter add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall nat add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface-list=WAN
А вот соответствующая конфигурация в Mikrotik Site 2 (Филиал):
/interface gre add local-address=192.168.99.2 name=gre-tunnel1 remote-address=192.168.99.1
/ip ipsec mode-config add name=cfg1 responder=no use-responder-dns=no
/ip ipsec peer add address=blablabla.sn.mynetname.net name=peer1 profile=profile1
/ip ipsec policy add dst-address=192.168.99.1/32 group=group1 proposal=proposal1 src-address=192.168.99.2/32 template=yes
/ip route add distance=1 dst-address=192.168.8.0/24 gateway=172.16.1.1
/ip address add address=192.168.9.1/24 comment=defconf interface=bridge network=192.168.9.0
/ip address add address=172.16.1.2/30 interface=gre-tunnel1 network=172.16.1.0
К сожалению, это не работает. У меня есть соединение IPSec, но GRE-каналы не работают, и маршруты недоступны.
