    CRS317-1G-16S+RM: CWDM/DWDM SFP+ оптика?
    CRS317-1G-16S+RM: CWDM/DWDM SFP+ оптика?, Аппаратное обеспечение
    anuser
    11.08.2017 14:30:00
    Здравствуйте, могу ли я использовать любые CWDM/DWDM SFP+ модули с CRS317-1G-16S+RM? Какой бы вы порекомендовали для 10 км? С уважением.
    psannz
    20.07.2018 07:31:00
    CWDM-MUX8A: https://mikrotik.com/product/cwdm_mux8a
    doneware
    20.07.2018 12:12:00
    У меня там работает DWDM ER SFP+, но он также совместим с оптикой DWDM ZR:
    [me@myswitch] /interface ethernet> monitor 16 once
     status: link-ok
     auto-negotiation: done
     rate: 10Gbps
     full-duplex: yes
     tx-flow-control: no
     rx-flow-control: no
     advertising:
     link-partner-advertising:
     sfp-module-present: yes
     sfp-rx-loss: no
     sfp-tx-fault: no
     sfp-type: SFP-or-SFP+
     sfp-connector-type: LC
     sfp-link-length-9um: 40000m
     sfp-vendor-name: RMC TEL
     sfp-vendor-part-number: SFP+-DWDM-ER-C31
     sfp-vendor-revision: A
     sfp-vendor-serial: 1552.52-ERG3P011
     sfp-manufacturing-date: 16-03-30
     sfp-wavelength: 1552.52nm
     sfp-temperature: 39C
     sfp-supply-voltage: 3.29V
     sfp-tx-bias-current: 54mA
     sfp-tx-power: 1.828dBm
     sfp-rx-power: -12.609dBm
     eeprom-checksum: good
     eeprom:
       0000: 03 04 07 20 00 00 00 00  00 00 00 06 67 00 28 ff
       0010: 00 00 00 41 52 4d 43 20  54 45 4c 20 20 20 20 20
       0020: 20 20 20 20 00 00 00 00  53 46 50 2b 2d 44 57 44
       0030: 4d 2d 45 52 2d 43 33 31  41 20 20 20 06 10 34 fa
       0040: 00 1a 00 00 31 35 35 32  2e 35 32 2d 45 52 47 33
       0050: 50 30 31 31 31 36 30 33  33 30 20 20 68 f0 03 64
       0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
       0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
       0080: 5a 00 f1 00 55 00 f6 00  8c a0 75 30 88 b8 77 24
       0090: ea 60 3a 98 d6 d8 44 5c  c3 c7 13 94 9b 83 18 a6
       00a0: 27 10 01 3c 18 a6 01 f5  3a 00 17 00 38 00 19 00
       00b0: 27 10 d8 f0 27 10 d8 f0  00 00 00 00 00 00 00 00
       00c0: 00 00 00 00 3f 80 00 00  00 00 00 00 01 00 00 00
       00d0: 01 00 00 00 01 00 00 00  01 00 00 00 00 00 00 44
       00e0: 27 4f 80 8d 6a 7a 3b 85  02 de 2d 48 00 07 00 00
       00f0: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
    MattRichards
    23.07.2018 02:27:00
    Похоже, что Mikrotik теперь продаёт CWDM SFP/SFP+ — https://mikrotik.com/product/s_c47dlc10d. На вики-странице указано, что FS.com 1310 работают, так что не вижу причин, почему версии с CWDM не должны тоже работать.
    doneware
    27.07.2018 16:58:00
    Честно говоря, до версии 6.31 уже были проблемы. Обычные (серые) SFP имеют другой код устройства, чем C/DWDM. Поэтому устройства Mikrotik их даже не распознавали. https://www.finisar.com/sites/default/files/resources/AN_2030_DDMI_for_SFP_Rev_E­2.pdf — посмотрите страницу 5: обычный SFP/SFP+ — 03h, а DWDM SFP — 0Bh. Я поднял этот вопрос, и ребята из Mikrotik решили всё за две недели. v6.31rc16 была первой версией с их поддержкой. Затем в следующей сборке добавили полную поддержку DDMI. И речь именно о DWDM с сеткой 50 или 100 ГГц, а не про BiDir, которые обычно называют «WDM», но на самом деле это просто двунаправленные трансиверы серого цвета с длинами волн 1310/1490 (или 1550) нм.
    doneware
    27.07.2018 17:03:00
    Ну, можно использовать и OADM, и всего один оптический кабель, чтобы добавлять или сбрасывать длины волн на каждом узле. Топология волокон будет просто линией или кольцом, но каждый узел (или несколько) можно подключить в виде звезды или двойной звезды — логическая топология такая. Мы так делаем уже много лет, только с DWDM, потому что в него можно впихнуть гораздо больше каналов, скажем 40 вместо 8 или 12. Но в целом это почти одно и то же — полностью пассивная оптическая система. И всё стоит копейки. К тому же скорость не имеет значения: можно делать 1G, 10G, (потом 25 или 50G), 100G, если хотите. Правда, при 10G хроматическая дисперсия становится проблемой на расстояниях свыше 30 км.
    chechito
    17.07.2018 01:42:00
    Mikrotik понимает важность CDWM
    CyB3RMX
    19.07.2018 22:55:00
    Откуда вы берёте эти обновления? Заранее спасибо!
