Итак, вот что у меня есть:
I now have the following Bridge _[admin@Nitel] > int [admin@Nitel] interface> print Flags: X - disabled, D - dynamic, R - running NAME TYPE RX-RATE TX-RATE MTU 0 R ether1 ether 0 0 1500 1 X ether2 ether 0 0 1500 2 X wlan2 wlan 0 0 1500 3 R wlan3 wlan 0 0 1500 4 R MyBridge bridge 0 0 1500 [admin@Nitel] interface> 1 R name=“wlan3” mtu=1500 mac-address=00:02:6F:31:1C:83 arp=enabled disable-running-check=no interface-type=Prism mode=bridge ssid=“lagose1” frequency=2412 band=2.4GHz-B scan-list=default-ism supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=“” basic-rates-b=1Mbps basic-rates-a/g=“” max-station-count=2007 fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none [admin@Nitel] interface wireless>_ Station _[admin@Apapa] interface> print Flags: X - disabled, D - dynamic, R - running NAME TYPE RX-RATE TX-RATE MTU 0 R ether1 ether 0 0 1500 1 X ether2 ether 0 0 1500 2 X wlan1 wlan 0 0 1500 3 R wlan3 wlan 0 0 1500 4 R MyBridge bridge 0 0 1500 [admin@Apapa] interface> 1 R name=“wlan3” mtu=1500 mac-address=00:02:6F:05:AA:05 arp=enabled disable-running-check=no interface-type=Prism prism-cardtype=200mW radio-name=“00026F05AA05” mode=station ssid=“lagose1” frequency=2412 band=2.4ghz-b scan-list=default-ism rate-set=configured supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps supported-rates-a/g=“” basic-rates-b=1Mbps basic-rates-a/g=“” max-station-count=2007 tx-power=default fast-frames=no dfs-mode=none antenna-mode=ant-a wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no update-stats-interval=disabled default-authentication=yes default-forwarding=yes hide-ssid=no 802.1x-mode=none [admin@Apapa] interface wireless>_ The wireless interface and ether are both bridged in both cases. The problem now is a laptop attached to the bridge can not ping the laptop attached to the station. But inside the MT I can devices attached. Help needed!!!
Вот перевод:
Итак, сейчас у меня такая картина с бриджем: _[admin@Nitel] > int [admin@Nitel] interface> print
Флаги: X - отключен, D - динамический, R - активен
ИМЯ ТИП RX-RATE TX-RATE MTU
Станция _[admin@Apapa] interface> print
Беспроводной интерфейс и Ethernet подключены к бриджу в обоих случаях. Проблема в том, что ноут, подключенный к бриджу, не может пинговать ноут, подключенный к станции. Но внутри MT я могу пинговать устройства. Нужна помощь!!!
