Я настроил две MT для проверки bonding. Следую инструкции здесь , но даже не пытается заработать. Нужна помощь, ПОЖАЛУЙСТА!
[admin@ColoBonder] ip> address print
Flags: X - disabled, I - invalid, D - dynamic
ADDRESS NETWORK BROADCAST INTERFACE
0 172.16.2.1/24 172.16.2.0 172.16.2.255 ether5
1 172.16.1.1/24 172.16.1.0 172.16.1.255 ether4
2 206.251.xxx.xxx/29 206.251.xxx.xxx 206.251.xxx.xxx ether2
3 10.10.10.1/24 10.10.10.0 10.10.10.255 ether2
4 3.3.3.1/24 3.3.3.0 3.3.3.255 bonding1
[admin@ColoBonder] interface> print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 X ether1 ether 0 0 1500
1 R ether2 ether 0 0 1500
2 R ether3 ether 0 0 1500
3 R ether4 ether 0 0 1500
4 R ether5 ether 0 0 1500
5 R eoip-tunnel2 eoip-tunnel 0 0 1500
6 R eoip-tunnel1 eoip-tunnel 0 0 1500
7 R bonding1 bonding 0 0 1500
[admin@ColoBonder] interface> bonding print
Flags: X - disabled, R - running
0 R name=“bonding1” mtu=1500 mac-address=FE:FD:00:00:00:03 arp=enabled slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none link-monitoring=none arp-interval=00:00:00.100 mii-interval=00:00:00.100 down-delay=00:00:00 up-delay=00:00:00 lacp-rate=30secs
[admin@ColoBonder] interface> eoip print
0 R name=“eoip-tunnel2” mtu=1500 mac-address=FE:FD:00:00:00:04 arp=enabled remote-address=172.16.2.2 tunnel-id=2
1 R name=“eoip-tunnel1” mtu=1500 mac-address=FE:FD:00:00:00:03 arp=enabled remote-address=172.16.1.2 tunnel-id=1
[admin@ClientBonder] > ip address print
0 172.16.2.2/24 172.16.2.0 172.16.2.255 ether3
1 172.16.1.2/24 172.16.1.0 172.16.1.255 ether2
2 10.10.10.2/24 10.10.10.0 10.10.10.255 ether1
3 3.3.3.2/24 3.3.3.0 3.3.3.255 bonding1
[admin@ClientBonder] > interface print
0 R eoip-tunnel2 eoip-tunnel 0 0 1500
1 R eoip-tunnel1 eoip-tunnel 0 0 1500
2 R ether1 ether 0 0 1500
3 R ether2 ether 0 0 1500
4 R ether3 ether 0 0 1500
5 R bonding1 bonding 0 0 1500
[admin@ClientBonder] > interface bonding print
0 R name=“bonding1” mtu=1500 mac-address=FE:FD:00:00:00:01 arp=enabled slaves=eoip-tunnel1,eoip-tunnel2 mode=balance-rr primary=none link-monitoring=none arp-interval=00:00:00.100 mii-interval=00:00:00.100 down-delay=00:00:00 up-delay=00:00:00 lacp-rate=30secs
[admin@ClientBonder] > interface eoip print
0 R name=“eoip-tunnel2” mtu=1500 mac-address=FE:FD:00:00:00:02 arp=enabled remote-address=172.16.2.1 tunnel-id=2
1 R name=“eoip-tunnel1” mtu=1500 mac-address=FE:FD:00:00:00:01 arp=enabled remote-address=172.16.1.1 tunnel-id=1
Связь работает, но нужно настроить резервирование, чтобы если одна линия выйдет из строя, соединение с местом назначения не слетело.
