    IPSEC VPN туннель не работает.
    IPSEC VPN туннель не работает., RouterOS
    saci
    30.11.2005 16:48:00
    Я начинающий пользователь Mikrotik роутера и пытаюсь настроить IPsec туннель между двумя Mikrotik роутерами, но туннель не работает. Версия RouterOS 2.8.28. Помогите, пожалуйста.
    **КОНФИГУРАЦИЯ РОУТЕРА 1:**
    `/ ip address`
    `add address=10.0.0.1/24 network=10.0.0.0 broadcast=10.0.0.255 interface=WAN comment="" disabled=no`
    `add address=192.168.10.254/24 network=192.168.10.0 broadcast=192.168.10.255 interface=LAN comment="" disabled=no`
    `/ ip firewall`
    `set input name="input" policy=accept comment=""`
    `set forward name="forward" policy=accept comment=""`
    `set output name="output" policy=accept comment=""`
    `/ ip firewall service-port`
    `set ftp ports=21 disabled=no`
    `set pptp disabled=yes`
    `set gre disabled=yes`
    `set h323 disabled=yes`
    `set mms disabled=no`
    `set irc ports=6667 disabled=no`
    `set quake3 disabled=no`
    `set tftp ports=69 disabled=no`
    `/ ip firewall src-nat`
    `add out-interface=WAN action=masquerade comment="" disabled=no`
    `add src-address=192.168.10.0/24 dst-address=192.168.20.0/24 action=accept comment="" disabled=no`
    `/ ip firewall connection tracking`
    `set enabled=yes`
    `set tcp-syn-sent-timeout=2m`
    `set tcp-syn-received-timeout=1m`
    `set tcp-established-timeout=5d`
    `set tcp-fin-wait-timeout=2m`
    `set tcp-close-wait-timeout=1m`
    `set tcp-last-ack-timeout=30s`
    `set tcp-time-wait-timeout=2m`
    `set tcp-close-timeout=10s`
    `set udp-timeout=30s`
    `set udp-stream-timeout=3m`
    `set icmp-timeout=30s`
    `set generic-timeout=10m`
    `/ ip ipsec policy`
    `add src-address=192.168.10.0/24:any dst-address=192.168.20.0/24:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=10.0.0.1 sa-dst-address=10.0.0.2 proposal=default manual-sa=none dont-fragment=clear disabled=no`
    `/ ip ipsec peer`
    `add address=10.0.0.2/32:500 secret="gvejimezyfopmekun" generate-policy=no exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 disabled=no`
    `/ ip ipsec proposal`
    `add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no`
    **КОНФИГУРАЦИЯ РОУТЕРА 2:**
    `/ ip address`
    `add address=10.0.0.2/24 network=10.0.0.0 broadcast=10.0.0.255 interface=WAN comment="" disabled=no`
    `add address=192.168.20.254/24 network=192.168.20.0 broadcast=192.168.20.255 interface=LAN comment="" disabled=no`
    `/ ip firewall`
    `add src-address=192.168.20.0/24 dst-address=192.168.20.0/24 action=accept comment="" disabled=no`
    `set enabled=yes`
    `/ ip ipsec policy`
    `add src-address=192.168.20.0/24:any dst-address=192.168.10.0/24:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=10.0.0.2 sa-dst-address=10.0.0.1 proposal=default manual-sa=none dont-fragment=clear disabled=no`
    `/ ip ipsec peer`
    `add address=10.0.0.1/32:500 secret="gvejimezyfopmekun" generate-policy=no exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 disabled=no`
    Tonda
    30.11.2005 19:00:00
    Маскировка в правилах src-nat должна быть на втором месте, правило принятия должно быть первым.
    saci
    30.11.2005 19:12:00
    Большое спасибо, туннель работает отлично.
