Я начинающий пользователь Mikrotik роутера и пытаюсь настроить IPsec туннель между двумя Mikrotik роутерами, но туннель не работает. Версия RouterOS 2.8.28. Помогите, пожалуйста.
**КОНФИГУРАЦИЯ РОУТЕРА 1:**
`/ ip address`
`add address=10.0.0.1/24 network=10.0.0.0 broadcast=10.0.0.255 interface=WAN comment="" disabled=no`
`add address=192.168.10.254/24 network=192.168.10.0 broadcast=192.168.10.255 interface=LAN comment="" disabled=no`
`/ ip firewall`
`set input name="input" policy=accept comment=""`
`set forward name="forward" policy=accept comment=""`
`set output name="output" policy=accept comment=""`
`/ ip firewall service-port`
`set ftp ports=21 disabled=no`
`set pptp disabled=yes`
`set gre disabled=yes`
`set h323 disabled=yes`
`set mms disabled=no`
`set irc ports=6667 disabled=no`
`set quake3 disabled=no`
`set tftp ports=69 disabled=no`
`/ ip firewall src-nat`
`add out-interface=WAN action=masquerade comment="" disabled=no`
`add src-address=192.168.10.0/24 dst-address=192.168.20.0/24 action=accept comment="" disabled=no`
`/ ip firewall connection tracking`
`set enabled=yes`
`set tcp-syn-sent-timeout=2m`
`set tcp-syn-received-timeout=1m`
`set tcp-established-timeout=5d`
`set tcp-fin-wait-timeout=2m`
`set tcp-close-wait-timeout=1m`
`set tcp-last-ack-timeout=30s`
`set tcp-time-wait-timeout=2m`
`set tcp-close-timeout=10s`
`set udp-timeout=30s`
`set udp-stream-timeout=3m`
`set icmp-timeout=30s`
`set generic-timeout=10m`
`/ ip ipsec policy`
`add src-address=192.168.10.0/24:any dst-address=192.168.20.0/24:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=10.0.0.1 sa-dst-address=10.0.0.2 proposal=default manual-sa=none dont-fragment=clear disabled=no`
`/ ip ipsec peer`
`add address=10.0.0.2/32:500 secret="gvejimezyfopmekun" generate-policy=no exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 disabled=no`
`/ ip ipsec proposal`
`add name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024 disabled=no`
**КОНФИГУРАЦИЯ РОУТЕРА 2:**
`/ ip address`
`add address=10.0.0.2/24 network=10.0.0.0 broadcast=10.0.0.255 interface=WAN comment="" disabled=no`
`add address=192.168.20.254/24 network=192.168.20.0 broadcast=192.168.20.255 interface=LAN comment="" disabled=no`
`/ ip firewall`
`add src-address=192.168.20.0/24 dst-address=192.168.20.0/24 action=accept comment="" disabled=no`
`set enabled=yes`
`/ ip ipsec policy`
`add src-address=192.168.20.0/24:any dst-address=192.168.10.0/24:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=10.0.0.2 sa-dst-address=10.0.0.1 proposal=default manual-sa=none dont-fragment=clear disabled=no`
`/ ip ipsec peer`
`add address=10.0.0.1/32:500 secret="gvejimezyfopmekun" generate-policy=no exchange-mode=main send-initial-contact=yes proposal-check=obey hash-algorithm=sha1 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 disabled=no`
`/ ip address`
`/ ip firewall`
`set enabled=yes`
`/ ip ipsec policy`
`/ ip ipsec peer`
`/ ip address`
`/ ip firewall`
`set enabled=yes`
`/ ip ipsec policy`
`/ ip ipsec peer`
